Continue
  • My Subscriptions
  • Events
PM810 losing their configuration at restart
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM810 losing their configuration at restart
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
sesa97267_bridg
sesa97267_bridg Contributor
Contributor
Posted: ‎2014-07-30 04:30 AM
2927
I have 2 PM810 which are not permanently powered and they sometimes lose their configuration (communication parameters, language etc..) at restart.
Do you have history of such a phenomenon or any clue why it could happen?
Are the settings stored in flash memory or through battery system? if so, is there a way to check battery status/capacity?
Best regards,
Tags (4)
  • pm
  • pm8
  • pm810
  • settings
Replies 8
Adrian_Dicea
Adrian_Dicea Champion
Champion
Posted: ‎2014-08-08 06:03 AM
2835
Did you get an answer from Tech Support on this issue?
sesa97267_bridg
Contributor
Posted: ‎2014-08-14 01:34 AM
Hi Adrian,
nothing so far. As they do not have the latest FW revision (they have n-1 version), I am considering suggesting them to upgrade and see...
Any other idea on your side?
Regards
farmer83
farmer83 Leader
Leader
Posted: ‎2014-08-14 09:00 AM
2835
The PM810 has no internal battery.  It will definitely lose the clock, but I never experienced it losing the program.
Adrian_Dicea
Champion
Posted: ‎2014-08-14 10:21 AM
2835
Jean-Christophe,
We have received your query, there is a technical case registered already and escalated to L4.
You will be constantly notified of what is going on by my colleague who handles the case.
Adrian
sesa97267_bridg
Contributor
Posted: ‎2014-08-19 04:58 AM
Hi John,
thanks for your feedback.
I have now a case open with Power Technical Support.
I will post the outcome of this issue when it is solved.
Posted: ‎2014-09-27 06:19 AM
2835
We have encountered configuration loss after restart in commissioning stage of several projects in Taiwan as well.
Please also inform me if there's a fix.
-Abon
sesa97267_bridg
Contributor
Posted: ‎2014-09-30 04:33 AM
Dear Chen,
the case was closed because I could not provide sufficient information on what was happening.
You should contact Power Technical Support and open a case also, that may help deeper investigations if we are several users facing this issue,
sesa56314
sesa56314 Leader
Leader
Posted: ‎2014-09-30 04:39 PM
For each device which have encoutered this issue, could you please report the values of modbus registers 8927, 8928 and 8929?
