Continue
  • My Subscriptions
  • Events
Concurrent connections from RS485 and Ethernet interfaces for PM5560
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Concurrent connections from RS485 and Ethernet interfaces for PM5560
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Tun
Tun Contributor
Contributor
Posted: ‎2024-03-07 10:14 PM
1325
Can anyone tested and used the PM5560 for the concurrent connections on both RS485 port and Ethernet port?
We are having a request to use this way to segregate the meter reading from two "separate" networks ( PME and non-SE BMS).
Thank you in advance.
Tun
  • PM5000
Mehran_Mehrnia
Champion
Posted: ‎2024-03-08 12:13 PM
Hi @Tun
The PM5560 has the capability to communicate simultaneously via serial RS485 and Ethernet ports with two different systems through Modbus.
Best Regards,
-Mehran
L3 Expert Technical Support Specialist
Mehran_Mehrnia
Champion
Hi @Tun
Best Regards,
-Mehran
Tun
Tun Contributor
Contributor
Posted: ‎2024-03-11 08:04 PM
Thank you, Mehran
