Metering & Power Quality
Hi Josef
You could use the Log Export module to send an email with logged data from either the ION7650 or the ION8650.
The Log Export module is described in the ION Reference, and you could create and configure the module using the advanced mode of ION Setup or through PME.
You can get the latest version of the ION Reference by searching "ION Reference" on the Schneider website.
cheers,
Alana
Is there any way that this is possible?
Hello Josef,
Once the meters are connected to a Power Monitoring Expert system, the on-board data will be downloaded automatically into a SQL Database and then read back/processed into the software.
Victor
Hi Josef
cheers,
Alana
Thank you Alana and Victor.
Big help!
