Ask: Accuracy on PowerTag Flex 160A (A9MEM1580) if installed on MCB 32A and recommendation for HMI Display?
Metering & Power Quality
Send InviteCancel
Normally, we want to propose using PowerTag A9MEM1542, but there is a condition where some of parameter requirement that needs to measure is not support by modbus register list on A9MEM1542 like:
Frequency,
Current Neutral,
Total Reactive Power,
Total Reactive Energy,
Total Apparent Energy
But those parameter above will support A9MEM1580.
We worried that there is an issue regarding the accuracy of parameter readings if we use A9MEM1580 and install on MCB 32A, even on the datasheet it is also say that this PowerTag can detect current starting from 100mA.
This FDM128 is an intelligent Ethernet switchboard display module and it is part of EnerlinX communication system. This display unit is compatible with Masterpact, Compact, PowerPact and PowerTag Link devices. It collects data from up to 8 devices over Ethernet, for a possibility of up to 160 PowerTag connected. FDM128 displays the measurements, alarms, and operating assistance data.
