what kind of ActiveX control is necessary to look at the trending & forecasting site at the ION 7650. I've get some warnings that i have to install to correct ActiveX control from the PowerLogic Website (see screenshot). The link is redirected to an other site.
Thank you for your help.
best regards
Lars
It is a Pro Essentials Graphing control I believe and it is also distributed with the ION Setup installer (but is not automatically installed since it is not required by ION Setup itself). Use Explorer to look in the main ION Setup folder after you've installed it and you'll find a file named "ProEssentials Graph Install.EXE" which when run, will install the Active X control if I remember correctly.
https://schneider-electric.box.com/ionsetup
Under the Installers/Updated Versions for the latest version of ION Setup.
Hello Robert,
many thanks for your fast reply. I've downloaded the IONSetup from the box and I shall test your solution if I visit the customer next time.
Greetings
Lars
Hello Robert,
short answer: it works!
Thank you
Lars
try to download it from here:
