Continue
  • My Subscriptions
  • Events
1PPS time synchronization signal for ION9000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • 1PPS time synchronization signal for ION9000
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic ION9000
Stuart_Cheng
Stuart_Cheng Contributor
Contributor
Posted: ‎2022-09-30 02:49 AM
2124
Hi All
In addition to the protocol mentioned below, does ION9000 also support the 1PPS time synchronization protocol? Thanks
  • Thumbnail of PowerLogic ION9000
    PowerLogic ION9000
View products (1)
  • ION9000
DanL
DanL Champion
Champion
Posted: ‎2022-09-30 03:42 PM
3
2104
No, the ION9000 does not support 1PPS for time synchronization. The internal clock typical drift is about 2ppm (5 seconds per 30 days).
Never user more than one external synchronization source at a time. The ION9000 supports the following methods for time adjustment and synchronization:
1. PTP
2. IRIG-B (demodulated)
3. NTP (and SNTP)
4. ION Protocol (serial or Ethernet)
5. serial RS485: Truetime/Datum, Arbiter, or Arbiter-Vorne
6. Line Frequency (relative to configured Nominal Frequency)
Replies 4
DanL
DanL Champion
Champion
3
2104
1. PTP
3. NTP (and SNTP)
Stuart_Cheng
Contributor
Posted: ‎2022-10-02 09:33 AM
Thanks @DanL
Stuart_Cheng
Contributor
Posted: ‎2022-10-02 07:50 PM
2045
Hi @DanL
Since there is a specification requirement for 1PPS from customers, is there any way we can make ION9000 available for 1PPS signal? Thanks
Charles_Murison
Champion
Posted: ‎2022-10-03 10:18 AM
Hello @Stuart_Cheng ,
Feature requests need to go through sales channels so that they can be feed into a tool used by offer managers to compare different feature requests.
Charles
