Which models of the SE7300 series room controllers can be used with the SC3000 series relay packs?
  • Which models of the SE7300 series room controllers can be used with the SC3000 series relay packs?
  • Cody_Failinger
    Cody_Failinger
  • sesa119747
    sesa119747
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-11 05:46 AM
EcoStruxure Building Expert, EcoStruxure Building Operation, Field Devices
SE7300 series Room Controllers
The SC3000 series relay packs allows existing line voltage wiring between the fan coil unit and temperature controller to be re-used. Only certain models of the SE7000 series room controllers can be used with the relay packs.
The SER7300 is used with the SC3000.
Refer to F-27797 SER7300 and SC3000 Series datasheet. Refer to the F-27777 SC3000 Series datasheet to select the appropriate relay pack for your application.
SE7000 series Room Controllers documentation can be found on The Exchange Download Center.
Labels (3)
  • EcoStruxure Building Expert
  • Field Devices
  • 12909
