Unable to Initialize Continuum Database after installing new SQL instance
  • Unable to Initialize Continuum Database after installing new SQL instance
  • David_Kendrick
    David_Kendrick
  • Cody_Failinger
    Cody_Failinger
  • SangKim
    SangKim
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 12:43 PM
Last Updated: Admiral David_Kendrick Admiral ‎2023-06-20 04:08 AM
After installing a new SQL server and installing CyberStation on a workstation PC, Database Initialization is unable to connect to the database.
Andover Continuum
  • SQL
  • Database Initialization
The Database has not been assigned with a correct owner.
  1. In SQL Server Management Studio, highlight ContinuumDB.
  2. Right Click on ContinuumDB.
  3. Select "New Query"
  4. In the query field type SP_ChangeDBOwner 'Andover97'
  5. Run the query
  6. Once the query returns Success, it should be possible to Initialize the Database successfully.
Tags (2)
  • 7263
  • DavidKendrick23
