Unable to Create a backup in DBCreate
  • Unable to Create a backup in DBCreate
  • Cody_Failinger
    Cody_Failinger
  • Roger_Bently
    Roger_Bently
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-07 04:01 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:35 PM
Unable to create a backup of an I/NET Seven Database using DBCreate, gets a backup failed error.
TAC INET
Windows XP, Windows Vista OS, with SQL 2000, 2003 and 2005.
Functionality of the host pc and the database seems to be inconsistent.
Option 1:
  1. Stop all of the SQL Services (SQL Server, SQL Agent, SQL Distributed Coordinator)
  2. Copy INetDb.mdf and INetDb_log.ldf to an alternate locations (located in C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Data)
  3. Restart all SQL Services.
  4. Launch DBCreate and remove the existing I/NET Seven Database.
  5. Create a new I/NET Seven Database.
  6. Stop all of the SQL Services (SQL Server, SQL Agent, SQL Distributed Coordinator)
  7. Copy the saved INetDb.mdf and INetDb_log.ldf over the newly created files.
  8. Restart all SQL Services.
  9. Launch DBCreate and attempt a backup.
Option 2 (If Option 1 does not work)
  3. Uninstall and Reinstall I/NET Seven.
  4. Stop all of the SQL Services (SQL Server, SQL Agent, SQL Distributed Coordinator)
  5. Copy the saved INetDb.mdf and INetDb_log.ldf over the newly created files.
  6. Restart all SQL Services.
  7. Launch DBCreate and attempt a backup.
Refer to How to Troubleshoot on DBCreate for more issues about DBCreate.
  • TAC INET
  • 4307
