The license server web displays: No such feature or vendor does not exist: taclic error
  • The license server web displays: No such feature or vendor does not exist: taclic error
  • Cody_Failinger
    Cody_Failinger
  • RobertAndriolo
    RobertAndriolo
  • Benji
    Benji
  • CraigEl
    CraigEl
  • JohnBoehmer
    JohnBoehmer
‎2018-09-11 01:56 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:15 PM
The FlexNet console shows the following error
Vendor daemon down: taclic
  • License Server
  • FlexNet
  • TACLIC
The taclic vendor daemon which serves the SmartStruxure licenses is down. This indicates that the vendor daemon either does not exist, or that another application using the same vendor daemon executable is present on the PC.
You can run one or more FlexNet license servers with different vendor daemons, but a given vendor daemon can only be run once at a time on the PC.
The SmartStruxure Building Operation vendor daemon is called taclic.exe. This can be seen as a process in the Windows Task Manager.
1. Make the SmartStruxure license server is properly installed
2. Follow SmartStruxure license and TAC Vista license on the same PC if both TAC Vista and SmartStruxure Building Operation is installed on the same PC.
  • 15127
