Access Expert Premise Installs on Windows OS
  • Access Expert Premise Installs on Windows OS
  • RandyDavis
    RandyDavis
  • Taylor_Leach
    Taylor_Leach
  • Cody_Failinger
    Cody_Failinger
  • Roger_Bently
    Roger_Bently
  • Robert_Davis
    Robert_Davis
‎2020-08-28 12:24 PM
on ‎2020-08-28 12:24 PM
Running Feenics applications on a Windows PC that is not server-based.
Access Expert
  • Access Expert Premise Software
  • Server 2016
  • Server 2019
If running a Hosted Instance or on a Premise then a Windows 7 Client Workstation may be used but is not recommended nor supported.  We ask that you use Windows 10 for Hosted clients.
However, if your solution is a Premise install, then the Windows Server must be a Server operating system.  If you have set up a Premise install on a Windows 7 PC and it works, please note that this is not a supported application and will not be supported.  You must upgrade your machine to Windows 10, Server 2016, or Server 2019.
Only use supported Windows Operation Systems such as Server 2016 or Server 2019.
  • EcoStruxure Access Expert
Tags (2)
  • 19271
  • TaylorLeach20
