Disabling redirection of http requests to https
ITA server (on-premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA server (on-premises only)
  • Disabling redirection of http requests to https
  • Mark as Read
  • Resetting the user password on the ITA server - on...
  • Disaster recovery
  • Configuring log rotation and archiving
  • Managing IT Advisor services
  • Reconfiguring locale on the IT Advisor server
  • Changing the IP address of the IT Advisor server t...
  • Enabling IT Advisor monitoring through Data Center...
  • Managing Webmin user accounts
  • Managing Webmin interface security
  • Software packages and services
  • Disaster recovery
EcoStruxure IT Support
Request Support
Back to ITA server (on-premises only)
  • Mark as Read
Picard EcoStruxureIT
‎2007-11-19 07:55 AM
Some of the systems communicating with ITA do not support https communication.
Http communication must be enabled on ITA 8.0 for you to be able to use ITA with these systems, like IT Advisor: Mobile, Portal, and IT Advisor: PRO Pack.
To handle this, a setting to disable redirecting http to https has been introduced in the server management interface (Webmin).
Warning
Use this option with caution and be aware of the reduction in security since your data will no longer be encrypted!
Unless you have enabled a secure connection in the ITA desktop and web clients, disabling the redirection will also mean your communication between the server and clients may be at risk.
Server configuration (Webmin) settings
