Configuring log rotation and archiving
ITA server (on-premises only)
Send InviteCancel
The server rolls the log files in /opt/jboss/server/isxo/log every day. You must now configure log archiving, otherwise the log files will continue to grow and take up too much space on the server.
Configuring archiving of JBoss log files
On the IT Advisor server, mount a folder in which to store the log files, for example /data/logarchive.
Open the Webmin web interface.
Type the address of your IT Advisor server in a Web browser.
On the IT Advisor server's download page, click Server Configuration.
Log on to Webmin using the user credentials created during the installation.
In the left menu, select System>Scheduled Cron Jobs.
Type a description. If you want to save the log archive to a different folder than /data/logarchive, change the path in the command.
In When to execute, select Daily (at midnight).
Other log files
You can configure log rotation for other server log files in the Webmin web interface.
In the left menu, select System>Log File Rotation.
Select the log files you want to rotate.
Click a log file line to open the Edit Log File page and change the default settings according to your wishes, such as location of the files or rotation interval.
Client log files
In IT Advisor, select Help>Download Log Files and save the server and client log files to a location of your choice.
The client log file is rolled in this location when the .log file exceeds 1 MB. The latest 10 files will be stored.
