EGX 150 Pin occupancy RJ 45 to RS-485
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • EGX 150 Pin occupancy RJ 45 to RS-485
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
Sven_Ortmann
Sven_Ortmann Schneider Alumni (Retired)
Posted: ‎2017-11-14 12:35 AM
1655
with the change from EGX100 to EGX150 RJ45 also the connection port changes. A customer wants to connect a symmetra mw with modbus serial. Which Cable of RJ45 should be used for TD+ and which one for TD- ?
Connection on EGX150:
Connction on Symmetra MW:
Daniel_Borle
Commander Daniel_Borle Commander
Commander
Posted: ‎2017-11-14 10:52 PM
1623
Hi Sven,
Referred to the Link150 manual PIN 4 from Link150 must be connected to PIN 3 of Symmetra, PIN 5 of Link150 to PIN 8 of Symmetra and PIN 8 of Link150 to PIN6 of Symmetra:
Replies 6
Daniel_Borle
Commander
1624
Hi Sven,
Sven_Ortmann
Posted: ‎2017-11-15 04:14 AM
Hello Daniel,
Thank you I found the documentation yesterday:
https://www.schneider-electric.com/en/faqs/FA323145/
samhari
samhari
Cadet
Posted: ‎2025-05-13 11:37 PM
I am trying to use EGX150 RJ45 (RS232) port to connect to the PLC Modbus serial DB9 port Which Cable of RJ45 should be used for Rx and which one for Tx  and what Pin number on the Quantum PLC serial DB9 do I use?
Romain_Polette
Kirk
Posted: ‎2025-05-14 04:58 AM
771
Hello @samhari ,
We do not have "ready to use" cable to convert RS232 RJ45 to SUB-D9. You can build your own with instructions below.
Pin-outs of the Link150 RS232 port is listed in the Instruction Sheet.
You can try to use Quantum SUB-D9 cable ref 990NAD21110  and connect an RJ45 connector on the the other side of the cable.
Romain POLETTE
Solution Architect - France Operations
samhari
samhari
Cadet
Posted: ‎2025-05-14 04:09 PM
Hello Romain,
Thank you for the reply and the links. Yes I tried following the pin configuration for the RS232 port over RJ45 cable to Modbus DB9 cable to the PLC Modbus serial port but my issue is that am not able to communicate to the PLC from the laptop as shown. Not sure if am using the right pin configuration for the serial DB9 Modbus plug to the PLC. any idea? hope am not confusing you.. attached diagram is what am referring to.
Regards
Sam
Romain_Polette
Kirk
Posted: ‎2025-05-15 12:44 AM
Hello @samhari ,
If you check p. 111 of the HW ref manual, you will find Modbus Port pin-outs for your CPU 434 12 unit.
IBM-AT = prefab cable, but if you know pin-outs for both Link150 RS232 RJ45 port and CPU434-12 SUB-D9 male, you can build your own cable.
Best we can do in this forum is to propose you the following wiring between Link150 and Quantum CPU.
Please also check that Modbus parameters (Baudrate, parity, etc.) are aligned between your devices.
Romain POLETTE
