Posted: 2020-07-05 07:11 PM . Last Modified: 2024-04-03 02:44 AM
our customer has multiple leak ropes connected with one Netbotz 570. what will happen if one cable cut/damage, for example total 5 cables if number 3 become faulty (cut/damage) what will happen with other cables and what will be the alarm on DCE.
(CID:143756624)
Hello Ali,
The leak rope sensors work on a conductivity basis. If a leak rope is broken at any point, the leak rope should still monitor for leaks, but only up to the broken point.
Kind Regards,
Cory
(CID:143756634)
Just to add to Cory’s answer, if there was somehow a short because of the damage, the sensor would report a leak until the damaged part is removed.
(CID:143756698)
Posted: 2020-07-05 07:11 PM . Last Modified: 2023-10-22 04:18 AM
