Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
SxOnGW1.1.0.43 and early: default file transfer settings do not apply?
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • SxOnGW1.1.0.43 and early: default file transfer settings do not apply?
126
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-03 11:25 PM . Last Modified: β€Ž2024-04-05 04:56 AM
1110
Hi all!
I found another bug in SxOn GW 1.1.0.43, which moved from earlier versions of SxOn GW: default file transfer settings do not apply. I.e., in SxOn GW I configured Device File Transfer Settings like this (the password is not visible, but it's entered there):
After applying these settings, I still see unauthorized FTP access attempts every day in the logs of my devices.
If you disable these Default Device Settings and create your own settings, then the problem disappears and errors in the device logs no longer occur.
Very thanks for the support.
(CID:125208534)
  • Asset Advisor
  • IT Expert
  • bug
Hi all!
From What is new in EcoStruxure IT:
StruxureOn Gateway 1.1.2.25
  • The console log no longer displays an error when the Symmetra PX250 is polled.
  • The password now updates as expected after the default or a user created file transfer configuration is modified.
  • The service log posted by Symmetra PX250 now shows data as expected.
  • Samsung BMS and Uniflair CRACs are now supported.
I can confirm, that the above problem is already fixed in the new version of SxOn GW 1.1.2.25.
Very thanks for the support πŸ˜€.
(CID:126175351)
Replies 4
Thanks for sharing πŸ˜€
(CID:125212614)
Hi Ditte Drewer Mathiasen,
Unfortunately, this bug is also present in the current version of SxOn GW 1.1.1.16. This is not good...
(CID:125212728)
Hi all!
(CID:126175351)
Posted: β€Ž2020-07-03 11:25 PM . Last Modified: β€Ž2023-10-22 04:04 AM
