Posted: β2020-07-05 03:01 PM . Last Modified: β2024-04-03 11:38 PM
Hi.
I see that on mobile app the data reported from sensor controlled by a Netbotz appliance disply only the pod name but some sensor are not connected directly to the Netbotz but could be controlled via SNMP or IPMI protocol. So in mobile app I see a lot of sensor data but I cannot understand correct sensor reference, for example I see battery age or battery voltage but I know that it referred to an UPS, but label of UPS is not displayed. For example this is what I see on NetBotz Advance View configuration:
and this the correspondance on mobile APP:
I aspect that instead appear Office_CED under Battery Age on mobile app the correct label must be APC04.
in the past app release this is displayed correctly.
Regards.
(CID:137108083)
Dear Davide Manassi,
Please tell us if you could solve your problem or not?
With respect.
(CID:137729888)
Posted: β2020-07-05 03:01 PM . Last Modified: β2023-10-22 03:53 AM
