Posted: 2020-07-05 03:01 PM . Last Modified: 2024-04-03 11:38 PM
Hi!
I would like to model my datacenter in DCO which is cooled by Alfa Lavals "Arctigo LSV". But there are no genomes in the library.
Would that be possible?
Regards
Fredrik
https://www.alfalaval.com/products/heat-transfer/finned-coil-air-heat-exchangers/finned-coil-air-coo...
(CID:137108011)
Hi Fredrik,
From the cooling point of view, modeling such systems (Alfa Lavals "Arctigo LSV") are not supported in DCO. As a sort of work around, perhaps using CRAC and/or downflow CRAC cooling units from Genome Library could be tried out.
However if the data center is monitored by DCE, which is integrated in DCO, then most preferably could also be to associate temperature sensors and then run the 3D view based on measured plan:
Kind regards
(CID:137727714)
Posted: 2020-07-05 03:01 PM . Last Modified: 2023-10-20 05:00 AM
