Posted: 2020-07-05 01:58 PM . Last Modified: 2024-04-04 12:19 AM
Hi, two questions:
Question 1: is it possible to configure the y-axis max and min. In the graphic the max is 62.0 and min is 55.0 F. I would like the span to be min 40 and max 100 F.
Question 2: I note significant, unphysical temperature hysteresis (saw tooth waveform between 57.2 and 59.5). Is this typical ?
Thank you,
(CID:134696481)
Dear nanoman,
Regarding your questions:
As far as I know, this is not possible in APC AV software. You can try to make Feature requests, and maybe you will be heard.
From my experience I will say, that it depends on the actual ambient temperature around the sensor. For example, such a temperature graph is very characteristic of server rooms where non-inverter cooling units are used (that is, when the compressor can either be turned on at 100% power or turned off altogether).
With respect.
(CID:137103312)
Posted: 2020-07-05 01:58 PM . Last Modified: 2023-10-22 03:24 AM
