Posted: 2020-07-04 03:03 AM . Last Modified: 2024-04-05 03:38 AM
Hi
when will the sensor detects the smoke status? Any threshold pre-configured in the sensor? If so , what’s that?
(CID:126883991)
Hi Annie,
I just hooked up a smoke sensor to a 450 and it gets detected but I don't see a threshold when I go to "configure pod". The only thresholds you can set however are based on state. The smoke sensor either detects smoke or does not and you can't set a threshold based on how much smoke it detects. It's like a door sensor, there's no almost closed state, it's open or closed.
I find no documentation on how much smoke will cause the sensor to trigger.
(CID:126884140)
Hi all,
Product management came up with the numbers and that along with the datasheet are now available in k-base:
http://www.apc.com/us/en/faqs/index?page=content&id=FA335679
(CID:126884863)
Hello Annie,
I also have same question with you and I fonud some document for your reference ,
Hope it usefully for you ,thank you .
Best Regards
(CID:126884716)
I instilled a series of netbotz 250 in several backstage APC, the problem is that in some of them the temperature/humidity sensor dont appear on display. what i can do do solve this issue?
(CID:126885526)
Wrong post. This is being addressed on the following post:
(CID:126885579)
Posted: 2020-07-04 03:03 AM . Last Modified: 2023-10-22 03:07 AM
