NBES0301 extender cable
  • EcoStruxure IT forum
  • NBES0301 extender cable
126
65
Back to EcoStruxure IT forum
jzurera
Lt. Commander jzurera
Lt. Commander
Posted: ‎2022-11-03 03:29 AM
3
1316
Hi team,
we want to install two NBES0301 spot fluid sensor to a Netbotz 250, but we need more distance than 15 ft. Is it possible to extend the lengh of the cable with a standard UTP cable?
Thanks in advance.
  • NetBotz
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2022-11-21 05:01 PM
In response to jzurera
According to the instruction sheet for NBES0301:
https://download.schneider-electric.com/files?p_Doc_Ref=SPD_JGAY-7DJNEA_EN&p_enDocType=Quick+start+g...
Note: You can extend the length of the cable up to 30.5 m (100 ft) using the RJ-45
coupling and standard CAT-5 cabling.
Hope this helps
BR,
TJ
jzurera
Lt. Commander
Posted: ‎2022-11-21 08:55 AM
1238
does anybody have this information?
Thanks in advance.
tjlaw
Lt. Commander
Hope this helps
BR,
TJ
sesa298777
Crewman sesa298777 Crewman
Crewman
Posted: ‎2023-01-09 02:20 AM
Hi Jzureea,
Referring to the NBES0301 - NetBotz Spot Fluid Sensor Installation Instructions
You can extend the length of the cable up to 30.5 m (100 ft) using the RJ-45 coupling and standard CAT-5 cabling.
Kindest Regards, Rich...
