Posted: β2020-07-05 11:58 PM . Last Modified: β2024-04-02 11:44 PM
I've being testing with ITA 9.0.4. I found that the web client inventory main page doesn't display Geo-location's summarized info like DCO does. DCO displays power, unit and rack info of each geographic location,which is very useful. Why ITA doesn't display? Is it a bug?
ITA screenshot:
Yilai
(CID:152080780)
Hi Yilai,
Many thanks for providing the useful data. Here are few comments that may be shared here (I sent you a direct message already):
We need to provide you a replacement ITA license, (since only the DCO license is merged in ITA and not the Colo license).
KPI's seemed to be restarted: via desktop client, Tools > preferences > Capacity History, plus possible reboot of the server. Then I could see the web client showing expected KPI's:
Kind regards
(CID:152567910)
Hi Yilai,
I will look into this and will get back to you as soon as possible.
Kind regards
(CID:152080866)
Hi Yilai,
It works fine with one of your earlier solutions, which I've tested short while ago. It seems I may need to run the test using the same solution as yours. I will contact you by direct email soon, thanks.
Kind regards
(CID:152080912)
Hi Yilai,
Kind regards
(CID:152567910)
Posted: β2020-07-05 11:58 PM . Last Modified: β2023-10-22 02:41 AM
