Posted: 2020-07-03 06:04 AM . Last Modified: 2024-04-08 11:08 PM
In DCE, how to configure the recipients of e-mail notification related to communication errors with NetBotz appliances?
It seems that by default, all users with a defined e-mail address receive the alert by e-mail and as I used remote users, their e-mail address are automatically imported from Active Directory
(CID:108825485)
Hi Yannic,
Yes, that is the default behavior. If you check the release notes for 7.4 however:
You'll see that this function has been addressed:
Edit email address for remote users
You can now change the email address for LDAP and Active Directory users.
(CID:108825487)
Hi Yannic,
(CID:108825487)
Hi Steve
Thanks for your answer and the reference to the last release note
I can see my question is in fact a Know Issue in DCE 7.3.1 and 7.4
"NetBotz Lost Communication Email Notifications are Sent to All Users"
It seems that unfortunately the Know issues are not indexed, I was not able to find it through the "Search" function of the help.se-dmaas.com
(CID:108825788)
Hi Yannic, Yes, I had a hard time finding it too. Someone else also made note of that. I actually found it more easily on the release notes that were installed in the product. Either way though, 7.4 should be a resolution to your issue. Steve
(CID:108825789)
Posted: 2020-07-03 06:05 AM . Last Modified: 2023-10-31 10:27 PM
