Posted: 2020-07-03 06:03 AM . Last Modified: 2024-04-08 11:09 PM
I have an issue where losses are not being display for Critical Power Distribution under the EE Dashboard. I have configured EE properties for the unit and all other data appears to be feeding to the dashboard. Any Idea what the issue could be. I have included screens of the unit configuration and the dashboard.
(CID:108825427)
Hi Brian Meade, thanks for posting. Lets see who can be of assistance here. @community any ideas? Kind regards Ditte
(CID:108825786)
Posted: 2020-07-03 06:04 AM . Last Modified: 2024-04-08 11:09 PM
Hi Brian Can you show me the energy system configuration, or even better can you share a backup of the solution? Best Regards Jacob Just
(CID:108826648)
Hi Brian Meade, did you see the comment above? Best, Stine
(CID:108827517)
Posted: 2020-07-03 06:04 AM . Last Modified: 2024-04-08 11:08 PM
Hi Brian Meade, Wondering if the reason for the Critical Power Distribution power loss not being showed in the graph is that it is to small compared to the rest of the power losses. Do you have measured values on the PDU's also? Maybe you can take a look at the power loss across the PDU. To see how big a loss there is. The estimated power loss is also very small (0.01 %). So there might be a power loss, but just so small that it can't be seen in the graph. Thanks Jesper
(CID:109447655)
Posted: 2020-07-03 06:04 AM . Last Modified: 2023-10-31 10:56 PM
