Posted: 2020-07-03 03:04 PM . Last Modified: 2024-04-08 01:06 AM
Hi Team ,
Can Netboz firmware V4.5.4 support TLS1.2 ?
If it can ,how can we enable it ? If not , when will it be available ?
(CID:116919234)
Hi Eric,
TLS 1.2 has been supported since v4.5.2, so it should be enabled by default.
See the Release Notes for each version on the page below.
https://dcimsupport.apc.com/display/public/SWDCDOC/PDF+Library#PDFLibrary-ReleaseNotesadditional.1
Regards
(CID:116919314)
Hi Eric,
Regards
(CID:116919314)
Posted: 2020-07-03 03:04 PM . Last Modified: 2023-10-20 05:05 AM
