Building Management System
  • EcoStruxure IT forum
  • Building Management System
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:26 AM . Last Modified: ‎2024-04-10 12:33 AM
628
Hi Team,
I have proposed the following units to a client and he is now requesting for a Building Management System to monitor them.
Kindly advise if there is any Schneider Electric solution for this units to be monitored.
  1. G55TUPSU60HS*2, G55TBATL10A*2
  2. NBRK0570*2, AP9335T*3, AP9335TH*2 & IMS0C10‐1*4
  3. Uniflair Cooling units
Felix
(CID:95354888)
  • Data Center Operation
  • NetBotz
  • power monitoring expert
628
Hi Felix, SE has several solutions that will monitor and/or control some/all of the devices you listed, such as StruxureWare Data Center Expert, StruxureWare Building Operations (BMS System) and SturuxureWare Power Monitoring System etc. I recommend you getting in touch with an Account Manager to help identify the customer needs and take it from there.
Ajay
(CID:95354890)
Hi Ajay, Thanks, and well noted. Regards, Felix
(CID:95355060)
Posted: ‎2020-07-02 11:26 AM . Last Modified: ‎2023-10-31 10:17 PM
