Posted: β2020-07-02 11:26 AM . Last Modified: β2024-04-10 12:33 AM
Hi Team,
I have proposed the following units to a client and he is now requesting for a Building Management System to monitor them.
Kindly advise if there is any Schneider Electric solution for this units to be monitored.
Felix
(CID:95354888)
Hi Felix, SE has several solutions that will monitor and/or control some/all of the devices you listed, such as StruxureWare Data Center Expert, StruxureWare Building Operations (BMS System) and SturuxureWare Power Monitoring System etc. I recommend you getting in touch with an Account Manager to help identify the customer needs and take it from there.
Ajay
(CID:95354890)
Hi Ajay, Thanks, and well noted. Regards, Felix
(CID:95355060)
Posted: β2020-07-02 11:26 AM . Last Modified: β2023-10-31 10:17 PM
