Send InviteCancel
Posted: 2023-03-1703:44 AM. Last Modified:
4 weeks ago
Virtual VievX Installation
I will install the ViewX server on another server. SCADA will run on another computer and VirtualviewX will run on another computer. Can you share a document about the settings necessary to integrate the Virtual viewX configuration with SCADA?
Just use the Geo SCADA Configure Connections tool on the VVX server to point the clients at the Geo SCADA Server. If you can run ViewX on the VVX server then that part set up correctly.
