Energy Hub IT firewall requirements
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • Energy Hub IT firewall requirements
Thierry_Baudard
Commander Thierry_Baudard Commander
8
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
EduardoFainblum
Commander EduardoFainblum Commander
5
Marcus_Gasper
Commander Marcus_Gasper Commander
4
Back to EcoStruxure Energy Hub
Sandeep_EK99
Crewman Sandeep_EK99
Crewman
Posted: ‎2023-03-21 10:16 AM
1076
Since Energy Hub is a cloud-based solution, what do I need to prepare with my client's IT? Do we need to open a specific port to allow connection to the cloud? We are going to be using a Panel Server that will connect through their local network.
  • Knowledge Base
Marcus_Gasper
Commander
Posted: ‎2023-03-21 11:08 AM . Last Modified: ‎2023-03-21 11:09 AM
Hi Sandeep,
Panel Server needs an internet connection with access to the Schneider Electric cloud services to send measurement data to Energy Hub. Panel Server sends all the data over HTTPS and uses the same ports on the network firewall as standard web browsers. This makes Energy Hub easy to integrate into the IT network.
If the IT network uses a proxy server, then you need to configure the Panel Server proxy server settings.
If the network uses a firewall, then it needs to be configured to allow access to the Schneider Electric cloud services (also called endpoints).
You can find all this information and additional guidelines for network security in the Energy Hub IT and Security Guide.
Marcus Gasper
Technical Communicator
Marcus_Gasper
Commander
Hi Sandeep,
Marcus Gasper
