Difference between Asset and Energy Hierarchy
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • Difference between Asset and Energy Hierarchy
Thierry_Baudard
Commander Thierry_Baudard Commander
8
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
EduardoFainblum
Commander EduardoFainblum Commander
5
Back to EcoStruxure Energy Hub
Esperanto
Lieutenant JG Esperanto
Lieutenant JG
Posted: ‎2023-03-27 07:52 AM
1
1077
Hello all,
I'm in the process of configuring my first Energy Hub system. I have published the gateway topology to Energy Hub, but I'm not clear on what is the difference between the Asset and Energy hierarchy configuration. Can someone help me understand?
Thanks!
  • Getting Started
David_Chapman
Commander David_Chapman Commander
Commander
Posted: ‎2023-03-27 09:08 PM . Last Modified: ‎2023-03-27 09:10 PM
The difference between the two hierarchies is that the Asset hierarchy defines a where equipment and devices are located and contained while the Energy hierarchy defines where and what a device or metering point is monitoring.  All of the Energy view in Investigate will be automatically set up by configuring the Energy hierarchy.
So let's take an example of a circuit breaker in an LV Switchboard in a building that monitors all of the energy going to the distribution panels on floor 1.
The Asset hierarchy will show the circuit breaker inside the LV Switchboard as a feeder in the building.  By default the Asset hierarchy should already be configured showing what devices are in equipment at the site.
The Energy hierarchy models where the devices are monitoring, and what usage they are monitoring.  So in this example, the energy hierarchy will show the circuit breaker that feeds the entire first floor as a total energy usage on the first floor.  Devices that have a usage assigned to the in the Panel Server will automatically be assigned that same usage in Energy Hub on the Energy hierarchy.  The only additional step will be to contextualize any additional Floors, Zones, etc in the Energy hierarchy as needed to reflect where the devices are monitoring.
David_Chapman
Commander
