Connect BCPM to Site Server via RS-485
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • Connect BCPM to Site Server via RS-485
Thierry_Baudard
Commander Thierry_Baudard Commander
8
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
EduardoFainblum
Commander EduardoFainblum Commander
5
EcoStruxure™ Energy Hub
Back to EcoStruxure Energy Hub
emendoz7
Crewman emendoz7 Crewman
Crewman
Posted: ‎2024-03-14 08:24 AM . Last Modified: ‎2024-03-14 08:56 AM
965
A customer is currently trying to connect  (4)BCPM's daisy-chained via serial to a Site Server.
1. Is it possible to connect a BCPM as a downstream device on the Site Server?
2. The customer has the optional RS-485 ports. Do we have an existing adaptor for these ports?
3. Do we need a gateway device?
Thank you in advance!
  • Knowledge Base
emendoz7
Crewman
Posted: ‎2024-03-15 11:06 AM . Last Modified: ‎2024-03-20 01:07 PM
Hi, I just wanted to post an update as I have already received help from the L3 support team.
1. Is it possible to connect a BCPMA as a downstream device on the Site Server? Yes, if the Site Server has the optional RS-485 card, we can connect a Modbus device downstream using a regular third party adapter such as: Pheonix Contact 2761499
The RS-485 in the optional card is 2-wire (half duplex). Using terminals 1 (D-), 2 (D+), 5 ground, shell (frame ground).
In addition, the COM port must be configured in Windows and a serial site must be created in the Site Server Device Manager. COM port # depends on the slot, optional card and interface.
2. The customer has the optional RS-485 ports. Do we have an existing adapter for these ports? See above.
3. Do we need a gateway device? Not required if there is an existing optional RS-485 card.
emendoz7
Crewman
