Network Management Card (AP9544) for Easy UPS 1-Phase Firmware v3.2.0.6 Release Notes
Easy UPS 1-Phase
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Easy UPS 1-Phase
  • Network Management Card (AP9544) for Easy UPS 1-Phase Firmware v3.2.0.6 Release Notes
  • Network Management Card (AP9544) for Easy UPS 1-Ph...
NMC Support
Request Support
Back to Easy UPS 1-Phase
Lt. Commander SwathiNaidu Lt. Commander
‎2025-03-26 03:21 AM
Affected Revision Levels
Component File Details
Easy UPS 1-Phase Application Windows:
snst_nmc3_eu1p_3-2-0-6.exe
Linux & macOS:
snst_nmc3_eu1p_3-2-0-6.tar.gz
UPS Application for Easy UPS models SRV1KL-IN,
SRVPM3KRIL-IN, SRVPM2KRIL-IN, SRV1KUXI-IN,
SRV2KUXI-IN, SRV3KUXI-IN, SRV1KI, SRV2KI,
SRV3KI, SRVPM1KIL, SRVPM2KIL, SRVPM3KIL,
SRV1KRI, SRV2KRI, SRV3KRI, SRV2KL-IN,
SRV3KL-IN, SRV3KI-E, SRV1KRI-E, SRVPM1KRIL,
SRVPM2KRIL, SRVPM3KRIL, SRV1KA, SRV2KA,
SRV3KA, SRV1KRA, SRV2KRA, SRV3KRA,
SRVLPM1KRIL, SRVLPM2KRIL, SRVLPM3KRIL,
SRVSL1KRARK, SRVSL3KRARK, SRV2KRI-E,
SRVPM1KIL-E, SRVPM6KRI, SRVPM10KRI,
SRVPM10KIL, SRVSPM5KRI, SRV6KUXI-IN,
SRV6KL-IN, SRVSVPM5KRIL, SRVSL3KRIRK,
SRVLPM3KRIL-IN, SRVPM6KIL, SRVPM10KRIL-IN,
SRV10KUXI-IN, SRVLPM3KRIL-IN, SRVSL1KRIRK, SRVSL2KRIRK, SRVSL3KRIRK, SRVLPM6KRIL, SRV15KUXI-IN, SRV20KUXI-IN.
For details on upgrading the UPS Network Management Card (NMC) firmware, see the User Guide.
New Features
New Feature
Support added for USB to Dry Contact Accessory for NMC (AP9811).
Security update
The customized .ini file name may optionally contain a CRC32 for integrity checking of the .ini file before processing.
Fixed Issues
Fixed Issue
The UPS fault alarm is now triggered only if there is a valid fault code received from UPS.
The External battery pack alarm text “battery pack X first level over voltage” is now changed to “Battery pack x full charged”.
Newly added External battery pack alarms are now translated to other languages such as Japanese, German, Chinese, French, Italian, Spanish, Portuguese, and Korean.
The first login banner message in NMC Web UI is now changed from "This Network Management Card includes a 12-month Support Contract. Firmware upgrades after this period will require an NMC Support Contract. See www.apc.com/upsnmc for more information" to "This Network Management Card includes a 1-year Secure NMC Subscription. Firmware upgrades after this period will require the purchase and activation of a new Secure NMC Subscription. Learn more at apc.com/secure-nmc"
The word site map is now correctly translated to the German language.
Fake alarm will not get logged when the configurations are changed through config.ini
Scheduled shutdown is now not triggered when Signal PowerChute Network Shutdown Clients is enabled.
When configuring a scheduled shutdown, now Signal PowerChute Network Shutdown Clients can be disabled and Turn Back On can be set immediately.
Security update
The following security vulnerability has been addressed in this release:
  • CWE-863: Incorrect Authorization.
The Network-Only user can only perform actions in the Web UI relevant to the user access level.
Known Issues
Known Issue
The Temperature and Humidity related information is displayed in the Help sections of CLI and Web UI, even though Temperature and Humidity sensors are not supported with AP9811.
AP9811 'Output Relay 2’ parameter values can only be configured using Web UI and SNMP and not via CLI.
It is not recommended to change the Normal State of Input Contact from default Open state.
The firmware version and model number are not displayed in CLI when AP9811 is connected first time to NMC. It is recommended to disconnect and re-connect AP9811 to NMC in order to read the AP9811 firmware version and model number.
‘Put UPS in Bypass’ command is not available in the Device control commands of the I/O Contact Control Policy page.
Events related to Input dry contact and Output relay are displayed only in English language in all NMC interfaces.
AP9811 Input dry contact Events are not supported in PCNS.
The word “name” and “Vx-rail cluster shutdown error” is only available in English language.
“UPS: Deleted a One-Time scheduled shutdown” Event is not correctly translated in Japanese language.
Battery pack related events, "Battery pack x full charge" & "Battery pack x remains fully charged" are available only in English language.
Some unwanted characters are displayed when Event logs are viewed in French language.
Events are not logged for enabling and disabling of Bypass when UPS OFF & Bypass Not allowed configuration settings.
During Scheduled Shutdown of UPS, the graceful shutdown of UPS doesn't end at the configured time.
Note: This issue is specific to SRV15KUXI-IN.
Runtime Calibration does not perform as expected due to discrepancies between the Nominal battery voltage and the Rated battery voltage.
Note: This issue is specific to SRVSPM5KRI.
When the Runtime Calibration is performed for SRVPM6KRI unit, it does not undergo the Runtime Calibration and displays the critical alarm "The battery is not installed properly” even while the battery is connected.
Hash Signatures
Windows
Signatures
CRC32
3F588000
CRC64
AD0520F85AD76058
SHA-256
1689AC882BAB5C99024A610FA2562B8118497A55F900AB149268F4E07DEEDC3A
SHA-1
94B3D99129A3E77A4CB65DC624DD541E0ABD0E5B
BLAKE2sp
E877411022DC1CA8E221BE46584E562DD89702321912DEE5942D9D64C4DA5F3E
Linux
Signatures
 CRC32
EC5C51AD
CRC64
FED40CA6592A3B10
SHA-256
B58022A876B3BF70ECE7CF5CDABE231300C779A7E0C56AEDE52DBBE225AA9B8E
SHA-1
763ED22574B2B5424F7F53C57F64CBFA784A6430
BLAKE2sp
A1C9D29B15DA38FC470B8BAEC3B1A26052E7CBD8CEDA50E6107E454F2FAA2B70
macOS
Signatures
 CRC32
05EF7DD0
CRC64
AE9A326DCB1BC6B1
SHA-256
CEC436153188615AE70281CF917AA3C57462CD27778FDF7742D24ECAB6E92AC7
SHA-1
4EEC3851883F3C25D696D2B9EB86B982BD910DFB
BLAKE2sp
26B263A2122EB86A564216C616D5A3080E36A50D0D677E8CBE21A3E9090DCAFE
