Send InviteCancel
For details on upgrading the UPS Network Management Card (NMC) firmware, see the User Guide on the APC website.
New Features
New Feature
Feature-based licensing for AP9544 has been removed, and you can now access all the NMC's features and functionalities.
Fixed Issues
Fixed Issue
While performing the bypass operation via NMC interfaces, the UPS goes into bypass mode as expected when "Signal PowerChute Network Shutdown Clients" is either enabled or disabled.
The text "License Activated" and the alarm "UPS Low battery condition exists" are available in all languages in the Web UI.
The CLI correctly displays the VAC of Bypass Upper Voltage as 242 and Bypass Lower Voltage as 161.
When the putUPSToSleepGracefully(3) value is set for the upsAdvControlUpsSleep SNMP OID, a graceful sleep operation is performed as expected.
Support added for SNMP OIDs for External Battery Pack information.
Known Issues
Known Issue
The NMC does not support runtime calibration. It is not recommended you use this option. Note: This issue is specific to SRVLPM6KRIL and SRV15KUXI-IN only.
The NMC interfaces (Web UI, CLI, SNMP and Modbus) incorrectly displays a runtime remaining value of 0 for battery disconnection. The LCD displays the correct value. Note: This issue is specific to SRVLPM6KRIL only.
The VAC for Bypass Upper Voltage and Bypass Lower Voltage are incorrectly displayed in the config.ini. Note: This issue is specific to 1-3kVA SKUs and SRVLPM6KRIL only.
When configuring a scheduled shutdown, it is not recommended you disable “Signal PowerChute Network Shutdown Clients” or that you set “Turn Back On” to Immediately.
