Network Management Card (AP9544) for Easy UPS 1-Phase Firmware v2.5.1.7 Release Notes
Easy UPS 1-Phase
  • EcoStruxure IT Help Center
  • Network Management Cards
  • Network Management Card 3
  • Easy UPS 1-Phase
  • Network Management Card (AP9544) for Easy UPS 1-Phase Firmware v2.5.1.7 Release Notes
  • Network Management Card (AP9544) for Easy UPS 1-Ph...
NMC Support
Request Support
Back to Easy UPS 1-Phase
Lt. Commander LFleming Lt. Commander
‎2025-02-07 06:01 AM
Affected Revision Levels
Component File Details
Easy UPS 1-Phase Application apc_hw21_eu1p_2-5-1-7. nmc3  UPS Application for Easy UPS models SRV1KL-IN, SRVPM3KRIL-IN, SRVPM2KRIL-IN, SRV1KUXI-IN, SRV2KUXI-IN, SRV3KUXI-IN, SRV1KI, SRV2KI, SRV3KI, SRVPM1KIL, SRVPM2KIL, SRVPM3KIL, SRV1KRI, SRV2KRI, SRV3KRI, SRV2KL-IN, SRV3KL-IN, SRV3KI-E, SRV1KRI-E, SRVPM1KRIL, SRVPM2KRIL, SRVPM3KRIL, SRV1KA, SRV2KA, SRV3KA, SRV1KRA, SRV2KRA, SRV3KRA, SRVLPM1KRIL, SRVLPM2KRIL, SRVLPM3KRIL, SRVSL1KRARK, SRVSL3KRARK, SRV2KRI-E, SRVPM1KIL-E, SRVPM6KRI, SRVPM10KRI, SRVPM10KIL, SRVSPM5KRI, SRV6KUXI-IN, SRV6KL-IN, SRVSVPM5KRIL, SRVSL3KRIRK, SRVLPM3KRIL-IN, SRVPM6KIL, SRVPM10KRIL-IN, SRV10KUXI-IN, SRVLPM3KRIL-IN, SRVSL1KRIRK, SRVSL2KRIRK, SRVSL3KRIRK, SRVLPM6KRIL, SRV15KUXI-IN, SRV20KUXI-IN.
For details on upgrading the UPS Network Management Card (NMC) firmware, see the User Guide on the APC website.
New Features
New Feature
Support added on Dell VxRail for PowerChute shutdown feature.
Fixed Issues
Fixed Issue
PowerChute clients turn off as expected when Sleep command is issued from the NMC.
The NMC Web UI correctly translates “Green Power Function” into Chinese.
Battery Discharge issues are no longer visible after the assignment of static IP to NMC AP9544.
Note: This issue was specific to SRV10, 15 and 20 KVA (UXI models).
The NMC now supports runtime calibration.
Note: This issue was specific to SRVLPM6KRIL and SRV15KUXI-IN.
The NMC interfaces (Web UI, CLI, SNMP and Modbus) now correctly display a runtime remaining value of 0 for battery disconnection. The LCD also displays the correct value.
Note: This issue was specific to SRVLPM6KRIL.
The VAC for Bypass Upper Voltage and Bypass Lower Voltage are now correctly displayed in the config.ini.
Note: This issue was specific to 1-3kVA SKUs and SRVLPM6KRIL.
Known Issues
Known Issue
When configuring a scheduled shutdown, it is not recommended you disable “Signal PowerChute Network Shutdown Clients” or that you set “Turn Back On” to Immediately.
External Battery Pack events are only displayed in English in the Web UI.
“UPS: Deleted a One-Time scheduled shutdown” event is not correctly translated in the Japanese Web UI.
“Name” and “Vx-rail cluster shutdown error” are only displayed in English in the Web UI.
Runtime Calibration does not perform as expected due to discrepancies between the Nominal battery voltage and the Rated battery voltage.
Note: This issue is specific to SRVSPM5KRI.
Hash Signatures
Signatures apc_hw21_eu1p_2-5-1-7.exe
CRC32     C0a053f9
CRC64 B00e640de3ed2687
SHA-256 263d78c9848ae94100420871eb88d7057b4899badf6cb7763d5e985d336e31aa
SHA-1     66dbb9145d194aff99636af5b7d7741d4703c6f6
BLAKE2sp 085f06d01f57daa50cdef1fd22670ad7587facfa162cf97b922c790e54e6d211
