YAML errors when attempting to run batch file to start the Mongo service during V3 on premise installation
  • YAML errors when attempting to run batch file to start the Mongo service during V3 on premise installation
  • Alan_Wood
    Alan_Wood
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • AbeMeran
    AbeMeran
‎2018-09-10 07:13 AM
Last Updated: Admiral Alan_Wood Admiral ‎2023-05-30 11:58 AM
Before installing Access Expert on premise server software, the Mongo DB must be installed and the Mongo service started, this requires creation and editing of a configuration file where the data and log directories are specified.
There have been many cases of YAML errors seen during V3 on premise installation when attempting to start the Mongo service.
EcoStruxure Access Expert
  • V3
  • Mongo DB
The YAML parser that reads the "mongod.cfg" file is very sensitive to the format of the configuration file including some very strict rules about spaces, double quotes and back slashes.
When editing the file, it helps to setup the text editor to display ALL characters which will show any hidden characters that might be causing a parsing error.
Ex. In Notepad++: Select View>Show Symbol> Show All Characters
  1. Space is needed between key and value pair.
  2. Enclose paths in double quotes.
  3. Double back slash required in Windows systems.
  • EcoStruxure Access Expert
Tags (9)
  • 19963
  • AccessExpert
  • AlanWood23
  • illegal
  • line
  • map
  • mongod.exe
  • onprem
  • yaml
