WorkPlace Tech Editor WorkPlace Tech Ribbon Bar: The add-in could not be installed
  • WorkPlace Tech Editor WorkPlace Tech Ribbon Bar: The add-in could not be installed
  • RandyDavis
    RandyDavis
  • David_Purser
    David_Purser
Guinan RandyDavis Guinan
‎2023-05-10 05:23 AM
Last Updated: Administrator CraigEl Administrator ‎2023-05-10 05:01 PM
When trying to open WorkPlace Tech Editor the following error is shown in a pop-up window.
The following error occurred while trying to launch the WorkPlace Tech Ribbon Bar: The add-in could not be installed.
EcoStruxure Building Operation, TAC IA Series
  • Building Operation Workstation (Workplace Tech Editor)
  • I/A Series WorkPlace Tech
An installation of the Visio Ribbon has not closed correctly from previous use of WorkPlace Tech Editor or standalone WorkPlace Tech.
  1. Open the Add and Remove function in Windows
  2. Select "Program and Feature"
  3. Look for an instance of the SE.WorkStation.IA.VisioRibbon when no WorkPlace Tech Editor is running.
  4. Right-click and uninstall.
  5. Open Workstation and launch WorkPlace Tech Editor
There are other conditions that can cause the ribbon not to run as well.  They are detailed in other articles
Similar Error Message Regarding Ribbon Bar
Unable to Load Ribbon
Labels (2)
  • TAC IA Series
  • RandyDavis23
100% helpful (2/2)
