WorkPlace Tech Editor Error Message
  • WorkPlace Tech Editor Error Message
  • CraigEl
    CraigEl
  • RandyDavis
    RandyDavis
  • David_Purser
    David_Purser
Guinan RandyDavis Guinan
‎2022-09-08 01:03 PM
Last Updated: Administrator CraigEl Administrator ‎2022-09-08 05:10 PM
An application will not open in WorkPlace Tech Editor with the following error:
WorkPlace Tech Editor returned errorOperation aborted (Exception from HRESULT: 0x80004004 (E_ABORT))
  • Building Operation Workstation (WorkPlace Tech Editor)
  • Visio 2013, 2016, and 2019
Visio crash causes the Add-In for WorkPlace Tech Editors fluent ribbon to become disabled
To re-enable the WorkPlace Tech Editor fluent ribbon bar, perform the following steps:
  1. Open Visio.  NOTE: Open Visio, not WorkPlace Tech Editor
  2. Select Options from the File menu.
  3. From the menu in the Visio Options window, select Add-ins
  4. At the bottom of the window, you will see a field that says 'Manage:' with a selection box after it, select 'Disabled Items' and then click the [Go] button.
  5. In the 'Disabled Items' window, select 'SE.WorkStation.IA.VisioRibbon' then click the [Enable] button.
  6. Close the open Visio windows and sub-windows.
After closing Visio, the WorkPlace Tech Editor fluent ribbon bar will be available in WorkPlace Tech Editor
  • RandyDavis22
100% helpful (1/1)
