Message "Unable to load WorkPlace Tech Ribbon for Visio" is displayed when attempting to open WorkPlace Tech
  • Message "Unable to load WorkPlace Tech Ribbon for Visio" is displayed when attempting to open WorkPlace Tech
  • RandyDavis
    RandyDavis
  • sesa116868
    sesa116868
‎2018-09-10 01:30 AM
Last Updated: Guinan RandyDavis Guinan ‎2022-05-03 11:33 AM
The following Popup window is displayed when attempting to open WorkPlace Tech.
WPTech
Unable to load WorkPlace Tech Ribbon for Visio.
There was a problem loading the WorkPlace Tech Fluent Ribbon for Visio, therefore, it will be unavailable.
TAC IA Series
  • Visio 2010, 2013, 2016, and 2019
  • WorkPlace Tech Tool release 5.8 or later
If Visio crashes when a third-party ribbon bar function is in use, Visio may lockout that ribbon bar, believing that something on that ribbon bar caused Visio to crash.  In this case, a menu function, selected from the WorkPlace Tech (WPT) ribbon bar was being processed at the time Visio crashed, therefore Visio locked out the WorkPlace Tech ribbon bar.
This is a system protection mechanism built into the ribbon bar handler in all Microsoft Office applications including Visio.
To re-enable the WorkPlace Tech ribbon bar, perform the following steps:
  1. Open Visio.  NOTE: Open Visio, not WorkPlace Tech.
  2. Select Options from the File menu.
  3. From the menu in the Visio Options window, select Add-ins
  4. At the bottom of the window, you will see a field that says 'Manage:' with a selection box after it, select 'Disabled Items' and then click the [Go] button.
  5. In the 'Disabled Items' window, select 'WorkPlaceTech.VisioRibbon' then click the [Enable] button.
  6. Close the open Visio windows and sub-windows.
After closing Visio, the WorkPlace Tech ribbon bar will be available in WorkPlace Tech.
  • TAC IA Series
Tags (2)
  • 6023
  • RandyDavis22
81% helpful (17/21)
