Voltage differences between RS485 transceivers in Generation 1 and Generation 2 Infinity Controllers.
  • Voltage differences between RS485 transceivers in Generation 1 and Generation 2 Infinity Controllers.
  • Chris_Asbury
    Chris_Asbury
  • AdamSteele
    AdamSteele
  • CraigEl
    CraigEl
  • JohnBoehmer
    JohnBoehmer
‎2018-09-11 09:45 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 04:39 PM
When looking at the waveforms on an Infinet bus some waves appear at an amplitude of 5 volts while other waves have a 3 volt amplitude.
Andover Continuum
  • RS485
  • Infinet transceivers
  • Pico scope
  • Oscilloscope
Generation I controllers such as CX9900 and i1 and earlier versions of Infinet controllers are manufactured with a 4.5 volt transceivers.
Generation II controllers such as the CX9680, i2 and b3 controllers are manufactured with a 3.5 volt transceivers.
It is perfectly fine to wire an Infinet bus that contains both first and second generation controllers.
For more information on RS485 see General Information on RS-485 Communication.
Tags (3)
  • 16513
  • infinet1
  • infinet2
