Vista reports can not be edited from a remote workstation
  • Vista reports can not be edited from a remote workstation
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
‎2018-09-10 08:30 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:37 PM
Vista reports fail to save to the server when they are being edited from a remote workstation.
TAC Vista
  • Vista
  • Microsoft Excel
When setting up remote workstations on a LAN or WAN, there are certain steps that must be taken. If the proper DCOM settings are not set up on every remote workstation as well as the computer that runs Vista server, there can be authority issues. Vista reports can be created but will not allow values or trends to be saved into the report. In some cases this has generated the error "The RPC Server is unavailable" as seen in Error: The RPC server is unavailable.
On ALL remote workstations and the main server:
  1. Run DCOM Config 1.0.2.2.exe found in Helpful Vista Utilities - Configure DCOM instantly, Register ASP.NET. Either select Server-Workstation or Server-Workstation-Webstation.
On the main server that will be used to run Vista Workstation:
  1. Run > dcomcnfg
  2. Expand Component Services
  3. Open Computers
  4. Right-click My Computer and choose properties
  5. Go to COM Security pane
  6. For Access Permissions and Launch and Activation Permissions choose to edit both Edit Limits... and Edit Default...
  7. Add users Anonymous and Everyone with Remote Access
  8. Go back to Component Services and open My Computer
  9. Open DCOM Config
  10. Browse for OPCEnum right-click and choose properties
  11. Go to Security pane
  12. Change the three options to
    1. Launch and Activation Permissions   -Use Default
    2. Access Permissions                        -Use Default
    3. Configuration Permissions                -Customize
      • Choose Edit > add Anonymous and Everyone with Remote Access
  13. Go back to DCOM Config and browse for TACOS right-click and choose properties
  14. Go to Security pane
  15. Change the three options to
    1. Launch and Activation Permissions  -User Default
    2. Access Permissions                       -User Default
  • 7742
