Helpful Vista Utilities - Configure DCOM instantly, Register ASP.NET
  • Helpful Vista Utilities - Configure DCOM instantly, Register ASP.NET
‎2018-09-07 09:35 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:14 AM
Error "Ensure that Vista Server is started" when the server is already running.
TAC Vista
  • Vista Server
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
Refer to Chapter 3.5 of the TAC Software Installation Manual for the network security and permissions settings required to run Webstation (DCOM). test
These are some utilities created by Benjamin Roswall at Schneider Electric Denmark. They are not official releases nor are they supported by Schneider Electric. While they have been tested and used successfully, they should be used at your own risk.
DCOM Config 1.0.3.0.exe: Configure DCOM for TAC Vista Network
If you want to run TAC Vista Web Applications on Windows Server 2003 Standard Edition, both Internet Information Services (IIS) and ASP.NET 2.0 must be installed. ASP.NET 2.0 must be installed and activated before you start installing TAC Webstation. Refer to Chapter 4 of the TAC Software Installation Manual for more information.
If you've made it this far, then it's time to refer to Chapter 3.5 of the TAC Software Installation Manual for the network security and permissions settings required to run Webstation (DCOM). Or just run this utility. Click the picture to download the utility.
Webstation installations will use Option 3. If Webstation doesn't come right up and start working after this, also download the next utility.
WEB.exe: Corrects common problems with Vista Webstation
This utility will install and register the versions of ASP.NET required for running Webstation on the server PC. There are other articles on the command prompt commands to accomplish this, but this utility will take care of it for you. Click the picture to download the utility.
After this utility finishes running, restart the PC as instructed.
Tags (4)
  • 3900
  • 500.12
  • benji
  • tool
