Unable to send out emails using Gmail SMTP server
  • Unable to send out emails using Gmail SMTP server
  • Cody_Failinger
    Cody_Failinger
  • RyanSuar
    RyanSuar
  • CraigEl
    CraigEl
‎2018-09-09 09:47 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 03:39 AM
Unable to send out emails using Gmail SMTP server (smtp.gmail.com) with the following error messages in the station's standard output.
"javax.mail.MessagingException: 530 5.7.0 Must issue a STARTTLS command first."
Authentication has been enabled in the system.properties file as per Mail Service in a Niagara R2 UNC station configured correctly but e-mails not being sent to the SMTP....
TAC IA Series
I/A Series R2
As with most public SMTP servers, like Gmail, the outgoing mail SMTP server requires TLS (Transport Layer Security) or SSL (Secure Sockets Layer) which I/A Series R2 does not support.
Use an SMTP server that does not require TLS or SSL.
  • TAC IA Series
  • 5255
100% helpful (1/1)
