Unable to Start Security Expert Data Sync Service
  • Unable to Start Security Expert Data Sync Service
  • RandyDavis
    RandyDavis
  • PeterEdvik
    PeterEdvik
  • JonGreen
    JonGreen
  • David_Kendrick
    David_Kendrick
  • DavidChild
    DavidChild
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • AdamSteele
    AdamSteele
  • Anonymous user
Commander JonGreen Commander
‎2020-09-11 06:53 AM
Last Updated: Janeway PeterEdvik Janeway ‎2022-07-04 04:54 AM
Data Sync Service won't run after installation
EcoStruxure Security Expert
Security Expert Server
Mismatch in authentication type during the installation of Security Expert Server and Security Expert Soap Service
First completely uninstall the Security Expert Soap Service and Security Expert Server...
Then reinstall Security Expert Server ensuring to UNTICK the box to hide advanced database configuration optionsSX Hide Advanced.png
When asked about Customize WCF TCP/IP Port, make note of your selection.
Please note that using TLS 1.2 is the recommended method for authentication.
Then reinstall the Security Expert Soap Service matching up the authentication type used for the Security Expert Server.
  • EcoStruxure Security Expert
Tags (4)
  • AdamSteele21
  • DavidKendrick20
  • JonGreen20
  • MahmoudSayed22
0% helpful (0/1)
