The status of a Forced BACnet value is not reflected in a Graphic or the Watch Window
  • The status of a Forced BACnet value is not reflected in a Graphic or the Watch Window
  • RobertAndriolo
    RobertAndriolo
  • Jonas_Brissman
    Jonas_Brissman
  • sesa116873_brid
    sesa116873_brid
  • CraigEl
    CraigEl
  • AbeMeran
    AbeMeran
‎2018-09-11 01:36 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 12:04 AM
The status of a Forced BACnet value is not reflected in a Graphic or the Watch Window.
  • Enterprise Server (ES)
  • Automation Server (AS)
This is functioning as designed.
It was designed so that the "Forced" status for BACnet values would not be displayed in graphics or the watch window.
For a workaround using a PE Script program to show the forced icon for a BACnet value see How to show the forced icon for a BACnet value in a Graphic.
In EBO version 3.0.1 and later this issue only occurs on internal BACnet points, points which are located in the Application folder under the BACnet interface for the SmartX server.
Tags (2)
  • 17174
  • JonasBrissman20
