SigmaX error - "This application failed to start because side-by-side-configuration is incorrect"
  • SigmaX error - "This application failed to start because side-by-side-configuration is incorrect"
  • DavidChild
    DavidChild
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • Gary
    Gary
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
  • RogerHa
    RogerHa
‎2018-09-11 03:25 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:33 PM
When starting SigmaX, an error is reported, the error is: - This application failed to start because side-by-side-configuration is incorrect. Reinstalling SigmaX does not help.
Satchwell Sigma Software
  • SigmaX
  • Windows 7
  • Windows 10
SigmaX error when trying to run on a Windows 7 or Windows 10 machine.
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. Click Start > All Programs > Accessories
  2. Right-click Command Prompt, and then click Run as administrator.
  3. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. Type the following command, and then press ENTER: sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
More Information about SFC scan can be found in this document: http://support.microsoft.com/kb/929833
At the command prompt, type the following command, and then press ENTER: sfc /scannow
The sfc /scannow command will scan all protected system files, and replace corrupted files with a cached copy that is located in a compressed folder at %WinDir%\System32\dllcache.
The %WinDir% placeholder represents the Windows operating system folder. For example, C:\Windows.
Note: Do not close this Command Prompt window until the verification is 100% complete. The scan results will be shown after this process is finished.
However Microsoft Visual C++ Redistributable may not be installed sfc /scannow will not detect this, the Visual C++ Redistributable will need installing. Please see Error when trying to run SigmaX.exe and RegSigmaX.exe for further information regarding this.
  • Satchwell BAS & Sigma
Tags (5)
  • 15123
  • DavidChild19
  • error
  • laptop
  • windows
0% helpful (0/1)
This is a heading
