Side-by-side error when starting SigmaX, RegSigmaX or SigView
  • Side-by-side error when starting SigmaX, RegSigmaX or SigView
  • DavidChild
    DavidChild
  • RyanSuar
    RyanSuar
  • Gary
    Gary
  • RobertAndriolo
    RobertAndriolo
‎2018-09-11 01:47 PM
Last Updated: Gary Schneider Alumni (Retired) ‎2024-03-06 04:07 AM
The following errors are seen when trying to run SigmaX, RegSigmaX or SigView.
The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail.
Application event log:
Activation context generation failed for "C:\SigmaX\Bin\RegSigmaX.exe". Dependent Assembly Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762" could not be found. Please use sxstrace.exe for detailed diagnosis.
Satchwell Sigma
  • SigmaX 7.0.6 on Windows 7 32-bit
  • SigmaX 7.09 on Windows 10 64bit
  • SigView
Microsoft Visual C++ 2005 redistributable has not been installed. It appears that SigmaX requires this version to run.
Either the Microsoft C++ 2005 is not installed, or if it is, then the Service Pack 1 (SP1) is required to be installed.
This can be checked under the Windows 'Apps and Features'.
Install Microsoft Visual C++ 2005 SP1 Redistributable Package (x86).
In some cases,  Microsoft Visual C++ 2005 SP1 Redistributable Package Security Update (x86)
is required to resolve the issue. The 32bit (x86) version should be installed if installing Microsoft Visual C++ 2005 SP1 does not fix the problem.
  • Satchwell BAS & Sigma
Microsoft Visual C++ 2005 SP1 Redistributable Package Security Update (x86).zip
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86).zip
Tags (4)
  • 17093
  • DavidChild19
  • DavidChild20
  • GaryMontague24
100% helpful (6/6)
