Sigma DNN Configuration for Flat Ethernet Networks
  • Sigma DNN Configuration for Flat Ethernet Networks
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
  • sesa125819
    sesa125819
‎2018-09-07 02:52 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-04 11:25 PM
Guidance is required for configuring a Sigma Distributed Network Node (DNN) when connecting it to a "Flat" Ethernet network.
Satchwell BAS & Sigma
  • Satchwell Sigma
  • Ethernet network
  • Ethernet or ARCnet subnets
General configuration advice for ensuring proper communication between Sigma controllers and the network via the DNN.
  • What Is a Flat Ethernet Network?
    A flat Ethernet network is a network architecture where all devices share the same broadcast domain and IP subnet.
    • There are no routers or subnets separating groups of devices.
    • All devices can communicate directly without routing.
    • Typically uses a single IP range and subnet mask, such as 10.158.0.0/16.
    • Simplifies configuration but may lead to scalability and performance issues in larger environments.
  • Network Configuration
    • On a flat Ethernet network, the DNN requires only:
      • IP address
      • Subnet mask
    • These settings, along with the DNN’s “Default Server” information, should be configured using the Sigma Device Configuration Utility (SDCU).
  • Routing Configuration
    • RIP (Routing Information Protocol) is enabled by default on the DNN.
      • If RIP is enabled, the DNN will broadcast the route to the sublan.
      • If RIP is disabled, a persistent route must be manually added to the Sigma server.
      • Refer to the article: Persistent routing on the Sigma server for detailed steps.
  • Modifying RIP Settings via Pocket Terminal
    • Disable RIP on port 5:
      • Launch Pocket Terminal
      • Enter: RIPD 5
      • Click Send
    • Enable RIP on port 5:
      • Enter: RIPE 5
      • Click Send
    • Check RIP status:
      • Enter: RIPS
      • Click Send
  • Satchwell BAS & Sigma
Tags (2)
  • 3271
  • CraigEllis25
