Security Expert SX-KLCS Touch Keypad cannot be brought online
  • Security Expert SX-KLCS Touch Keypad cannot be brought online
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
  • CraigEl
    CraigEl
  • David_Kendrick
    David_Kendrick
‎2018-09-10 07:46 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-11 06:46 PM
The SX-KLCS Keypad is offline in the Client and shows ' Keypad 256 error address size' on screen
If you attempt to adjust the Keypad Address in the Client it is not even visible
EcoStruxure Security Expert
Security Expert SX-KLCS-B, SX-KLCS-W
SX-KLCS Keypads are normally delivered brand new to site with a default Keypad Address of 256 which the SP-C controllers cannot use and the Security Expert Client cannot even recognize to change the address via software
The Keypad's address must be manually changed to a value between 1 - 254 using its touch pad.
Keypad AddressKeypad Address
Please refer to the full SX-KLCS_Security_Expert_Touch_Sense_LCD_Keypad_Installation_Manual from which this extract was taken.
Once the Keypad Address has been set to a value between 1- 254 the Keypad should then be visible to the Client and you should be able to bring it online as usual.
The SX-KLCS Keypad will now display 'Security Expert by Schneider' by default.
  • EcoStruxure Security Expert
Tags (2)
  • 19822
  • AdamSteele21
