SE7000 Series RS-485 transceiver unit load
  • SE7000 Series RS-485 transceiver unit load
  • RobertAndriolo
    RobertAndriolo
  • Jeff
    Jeff
  • RyanSuar
    RyanSuar
  • CraigEl
    CraigEl
‎2018-09-11 01:28 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 10:36 PM
EcoStruxure Building Expert, EcoStruxure Building Operation
SE7000 series room controllers
The room controller RS-485 transceiver unit load is not included in the data sheets. This information is needed to determine the number of BACnet MS/TP devices per RS-485 segment.
Refer to Application Note AN05-RS485-VT7000 and Quick Guide RS485-VT7000. The links to these documents can be found in MS/TP and Modbus RS485 Communications on StruxureWare Automation Server
Labels (2)
  • EcoStruxure Building Expert
Tags (4)
  • 16887
  • se7200
  • se7300
  • se7600
