SE7000/SE8000 Series BACnet Communication disconnects
  • SE7000/SE8000 Series BACnet Communication disconnects
  • AdamSteele
    AdamSteele
  • Ramaaly
    Ramaaly
  • JohnBoehmer
    JohnBoehmer
  • PatrickDumas
    PatrickDumas
Lt. Commander Ramaaly Lt. Commander
‎2021-10-27 12:10 PM
Last Updated: Picard RobertAndriolo Picard ‎2021-10-27 06:53 PM
SE7000/SE8000 controllers are randomly going offline or are undiscoverable on BACnet network.
EcoStruxure Building Operation, EcoStruxure Building Expert
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE7000
  • SSL SE8000
Improper terminations of the BACnet MS/TP communication cable.
The REF (reference) Terminal is a BACnet Reference which is a voltage reference required by BACnet testing lab (BTL) and it is rarely used in the industry. If not used as a reference, The Ref terminal should be left empty. It is not a terminal to land a shield nor a ground.
At each thermostat (Cable Junction) :
  1. Connect the (+) and the (-) wires
  2. Twist the shields together
  3. Tape around the cable to prevent short-circuit. Ground the shield at one end only (usually on the BAS side) and leave the REF terminal empty
  4. Ensure that the shield wire is not connected to the REF (Reference) terminal.
Labels (2)
  • EcoStruxure Building Expert
  • RamaAly21
100% helpful (1/1)
